Big hammer, pry bar, and cross fingers!!!!!!!!!!
tg
08-06-2004 19:50:54
I'm working on a JD 318 and trying to pull the flywheel off. Any ideas on doing so, or do you get the big hammer and pry bar out and do the old hit the crank and pry on the flywheel deal?
JT
08-07-2004 08:57:52
 Re: Big hammer, pry bar, and cross fingers!!!!!!!! in reply to tg, 08-06-2004 19:50:54
Make sure you pull it with a flange puller. A big hammer can do some major damage. The biggest is if you strike a flywheel hard enough it can knock the magnets out of the flywheel. There are ceramic magnets under the flywheel that charge the battery, and if one of them get shattered or broke, then comes a new flywheel. Cost probably over $200.00
john d
08-07-2004 06:35:48
My advice is to obtain the correct puller. Small engine flywheels of this type should be pulled from the center part of the wheel, not pulled or pryed from the edges. On the other hand, if you feel lucky.....
Dannie
08-07-2004 01:19:49
You can damage flywheel with big hammer use a flywheel puller cost less than new flywheel.
RED TAIL HAWK
08-07-2004 09:18:35
 Re: Big hammer, pry bar, and cross fingers!!!!!!!! in reply to Dannie, 08-07-2004 01:19:49
Doing dumb things always costs us big money. Rent a flywheel puller,good luck
mandingo
08-11-2004 05:46:17
 Re: Big hammer, pry bar, and cross fingers!!!!!!!! in reply to RED TAIL HAWK, 08-07-2004 09:18:35
dont b banging on no flywheel.go buy or rent a puller .
