1 last chance before Junk Pile
Farmall Don
08-20-2004 07:17:42
Since I cant figure out why I get just a click under the dash when I try to start the 1450 Cub Cadet, I wanted to see how everthing worked. I jumped the starter (pos bat. terminal to pos starter terminal) and everything ran fine for a few minutes. Tried the PTO Clutch and it worked then just shut off. Then the engine sputtered and quit. Now it wont start at all. I get spark but there isnt any "click" when I turn the ignition switch. What did I do now?
Kent of SW MO
08-21-2004 08:16:12
 Re: 1 last chance before Junk Pile in reply to Farmall Don, 08-20-2004 07:17:42
If you are going to throw it away, throw it my way as I can easily fix. Do not give up on this 1450. It will be running when the MTD/CC of today are long forgot about.
Kent
tim in wi
08-20-2004 16:29:07
sounds like eletric clutch drawing down batt. charge batt. retry should start and run. turn on pto will run a wile and die out. feild winding in clutch shorted replace winding or new clutch hope this helps gl tim
CP in MN
08-20-2004 18:33:28
 Re: 1 last chance before Junk Pile in reply to tim in wi , 08-20-2004 16:29:07
Huh..... .????? ????? ????? ???
R Bedell
08-20-2004 08:59:50
Go here for the Wiring Schematic for your Cub. This well help you tracing down your problem. Your Brother-In-Law should be able to see through this:
www.ihregistry.com/ref/Diagrams/cubwire4.html
R Bedell
08-20-2004 08:10:15
Don....where are you located...????
Farmall Don
08-20-2004 08:21:36
 Re: 1 last chance before Junk Pile in reply to R Bedell, 08-20-2004 08:10:15
South Central Wisconsin
R Bedell
08-20-2004 08:33:01
 Re: 1 last chance before Junk Pile in reply to Farmall Don, 08-20-2004 08:21:36
Two questions here:
(A) Are you electrically knowledgable??... meaning to be able to trace down electrical circuits, and (B) Do you have a VOM meter....???
Farmall Don
08-20-2004 08:48:37
 Re: 1 last chance before Junk Pile in reply to R Bedell, 08-20-2004 08:33:01
Not as knowledgable as I would like to be, but I was going to ask my brother in Law (Electrician) to give me a hand tomorrow.
Bob
08-20-2004 09:14:55
 Re: 1 last chance before Junk Pile in reply to Farmall Don, 08-20-2004 08:48:37
That tractor is too good to give up on! When you find the poor connection, it will be such a simple little problem it will amaze you!
Farmall Don
08-20-2004 10:00:25
 Re: 1 last chance before Junk Pile in reply to Bob, 08-20-2004 09:14:55
Thanks for the encouragement. When it goes electric I just shiver. Thanks
Ryan
08-20-2004 15:34:55
 Re: 1 last chance before Junk Pile in reply to Farmall Don, 08-20-2004 10:00:25
Where in South Central WI? I might be able to give you a hand.
