Converting a BS model N to K1
'52 Farmall H
08-30-2004 15:35:20
Why do I need to lower the compression to run on kerosene? My engine has already lost compression due to wear. What would happen if I didn't put two head gaskets in?
Lou
08-31-2004 07:38:30
 Re: Converting a BS model N to K1 in reply to '52 Farmall H, 08-30-2004 15:35:20
Kerosene has a very low anti-knock rating. Too much compression and it will knock worse than a diesel..... for a while.
'52 Farmall H
08-31-2004 14:26:51
 Re: Converting a BS model N to K1 in reply to Lou, 08-31-2004 07:38:30
Do you mean the engine would self-destruct? Thanks.
Dannie
08-31-2004 02:51:47
Its timing of engine.
'52 Farmall H
08-31-2004 14:21:56
 Re: Converting a BS model N to K1 in reply to Dannie, 08-31-2004 02:51:47
Is that why I need to open the spark plug gap? Thanks.
lucas
08-30-2004 17:39:12
try it,i think it would blow the two gaskets but you never know..lucas
'52 Farmall H
08-31-2004 14:20:28
 Re: Converting a BS model N to K1 in reply to lucas, 08-30-2004 17:39:12
FYI: The B&S manual I saw said to use two head gaskets and open the spark plug gap(I can't remember how much). Thanks.
