jd 318 no power
alan suter
09-03-2004 20:20:39
Hello I have 318 hydro mower tractor,just overhauled and it still has no power. the timing was set the solid stat ign fixture and pin replaced. rings and pistons changed ,valve jod done.??? any ideat it has and onan b43g-ga018/4135 engine.
chad
09-04-2004 07:49:35
 Re: jd 318 no power in reply to alan suter, 09-03-2004 20:20:39
What is the compression?
Mazz
09-03-2004 21:05:24
Alan - Assuming that everything done, was done correctly, there are a few other possible issues.
1. Governor linkage out of adjustment?
2. Fuel filter bad?
3. Fuel pump weak?
4. Rings did not seat? (check compression)
5. Crankcase breather/reed valve broken or plugged?
6. Valve clearance is not correct?
7. Exhaust restriction?
8. Choke or carb out of adjustment?
Dave
