15.5 BS shearing ignition pins
sumwharnohio
10-06-2004 11:46:41
Do not see any reason for this to occur as flywheel turns fine, nothing bent or obstructed underneath. But have replaced 3 pins so far, lined up splines with new key reassemble, try to start and pin shears?????
Any help??
bbowlin
10-08-2004 19:15:01
 Re: 15.5 BS shearing ignition pins in reply to sumwharnohio, 10-06-2004 11:46:41
The torque spec is 55 to 65 ft-lbs for the flywheel nut.
MAC,IL
10-06-2004 13:43:49
As mentioned it has to be "tight". Also use quality keys and absolutely no oil or the shaft. Also be sure washer in on the right way.
Bob
10-06-2004 12:10:56
If your are talking about the flywheel key, and it's repeatedly shearing, you're not tightening the flywheel enough. if you post the engine model number, someone may know a torque value for it, but it's gotta be TIGHT!!!
txblu
10-06-2004 12:18:46
 Re: 15.5 BS shearing ignition pins in reply to Bob, 10-06-2004 12:10:56
Took de words rite outta me mouth. Grin
I use an impact tool and drive till the socket quits turning and then a couple more smacks.
Mark
unclfixit
10-08-2004 19:25:04
 Re: 15.5 BS shearing ignition pins in reply to txblu, 10-06-2004 12:18:46
do you have the right ign. cdi pack, and is it on right? some can be put on upside down.
