Carbueretor Settings and Compression for BS 10HP
Kelly Wright
05-02-1999 14:34:13
I'm preparing to do a little work on my 10 HP Simplicitty which is about 27 years old as near as I can tell. In particular, I'm planning to rebuild the carburator.
The engine model number appears to be 243431 0627-01.
Does anyone know both the low speed and high speed adjustment setting (how many turns) as well as what the engine compression should be?
I intend to check the compression before doing the carb work.
Thanks...
Bill
05-06-1999 18:02:06
 Re: Carbueretor Settings and Compression for BS 10HP in reply to Kelly Wright, 05-02-1999 14:34:13
Spin the motor backwards by hand if it rebounds your compression is fine. You'll probably have some difficulty getting a good compression reading spinning it with the starter, many if not most BS motors us their compression release scheme that prevents a good read at low RPM.
