Big Roper
Jeremy R
10-19-2004 18:56:07
I just got an older roper mid to late 70's model. 16hp briggs It was sold under white outdoor label. it is verey much likea sears suburban. can any one help me locateing some manuals? I think the model is #TS2227AW.
stronics
10-23-2004 05:06:19
 Re: Big Roper in reply to Jeremy R, 10-19-2004 18:56:07
I'm sorry I can't help you with the manuals but I've worked on several and all have had the cooling fins blocked by grass mixed with oil from leaking flywheel side seal. The valves will freeze up from overheating and strip the cam or crank gear. Something to check so you won't have to deal with a new engine maybe.
Good luck with it, it's a nice tractor.
David
