Engine stalls under load.
Mike Kal
05-03-1999 13:42:01
I have a 3HP edger with B&S engine. It starts easy and runs fine until the engine is put under moderate strain. It stalls out even if the load on the engine is removed when it begins to stall out. The engine then restarts easy but will stall again when under load. Where should I begin to look for the problem?
Sam
05-08-1999 02:10:20
 Re: Engine stalls under load. in reply to Mike Kal, 05-03-1999 13:42:01
Follow the advice of those who tell you to check the carb. and the govenor. Sam
Pete in Ks.
05-04-1999 12:05:01
The govenor spring is wrong,or broken or missing.
Kelly Wright
05-04-1999 09:27:30
I'd pull the spark plug immediately following the stall and check the color.
If it's "whiteish" in color, it's running lean. If it's quite dark it could be running too rich (though I doubt it will be rich).
In either case, the carb needs adjustment.
If the plug is a chocolate brown color (normal), then I'd move on to the ignition system.
Have you tried installing a new, properly gapped spark plug?
GMAN
05-03-1999 22:31:13
Check the governor/linkage make sure it's working. Carb. might be set to lean also.
