Backfiring
plh_in
10-28-2004 05:15:17
I have a DeutzAllis 916 that ran fine all summer long after I installed a carb kit & new float. After the tractor sat for ~1 month, it was time to cut grass for the last time.
When running the tractor, the engine would backfire occasionally and now, it will hardly stay running....u have to fiddle w/ the choke, throttle to keep it going....plus it continues to backfire.
It has a K341 if I rememeber correctly. Any help as to what I should look at as the cause ???
Thanks for any help!
txblu
10-29-2004 07:13:30
 Re: Backfiring in reply to plh_in, 10-28-2004 05:15:17
"All of the above".
Joe C
10-28-2004 18:11:03
POINTS. had same prob on my Farmall
Dannie
10-28-2004 13:47:10
Dirt or water in gas,bad plug,or points need cleaned & gaped.
catmandoo
10-28-2004 18:34:43
 Re: Backfiring in reply to Dannie, 10-28-2004 13:47:10
also check condenser ,if it's loose it will back fire also.
