11hp I/C bS motor
Poldark
10-30-2004 23:23:19
Hi I have a 11hp I/C b&S motor on my ride on, trouble is it has an intermittant fault. some times it starts and sometimes it doesn't. when it does it runs for 5 to 15 minutes and stops and won't restart. took the coil to have it checked one place said it was faulty the other two places said it was fine, when it won't run there is no spark at the plug
Thanks if anyone can help
ANON
10-31-2004 06:32:55
 Re: 11hp I/C bS motor in reply to Poldark, 10-30-2004 23:23:19
Just put a new solid state coil kit in it and double check all your wires to make sure they are not grounding out anywhere. If it quits again, unplug your key switch and see if it has spark then. If it does, your key switch is bad.
