14 hp allis chalmers
DAVE TRUE
11-01-2004 15:58:35
I have a allis chalmers with a 14 hp kohler i have spark and when i spray some carb cleaner in the throat of the carb it wont even act i wants to start not sure why i removed and cleaned the carb but nothing any help would be appreciated thanks Dave
KennyW
11-02-2004 14:20:04
 Re: 14 hp allis chalmers in reply to DAVE TRUE, 11-01-2004 15:58:35
The Starting fluid won't do anything if your intake valve is not opening. Take the carb off and see if the valve is moving while you crank the engine. Just because you have spark doesn't mean that it is enough spark. Is it a Champion H10C plug or Autolite 216? Sometimes when spark is weak, the pressure of the compression stroke can blow out the spark. Reduce the gap of the plug slightly, spray some ether into the plug hole and try to fire it up. This all assumes the 14 hp is a K Series K321.
Let us know how you make out. Kenny
Dave True
11-07-2004 08:30:55
 Re: 14 hp allis chalmers in reply to KennyW, 11-02-2004 14:20:04
thanks i will try that Dave
