14 Horse Tecumseh Engine
John Yeandle
11-21-2004 08:13:22
Can I get some specs for this engine? I'm rebuilding this engine and need torque specs. Also need specs on engine clearances (valves, piston rings, crankshaft, piston/cylinder wall, etc.)Thanks in advance.
Gene Davis (GA)
11-21-2004 19:27:29
 Re: 14 Horse Tecumseh Engine in reply to John Yeandle, 11-21-2004 08:13:22
I can provide you with a repair manual for this engine if interested. e-mail if interested gadavis@direcway.com Mark the subject line; Tecumseh manual Gene Davis
John Yeandle
11-21-2004 15:53:09
This engine is out of a G-14 Bolens lawn tractor. The engine model is a TEC. HH140-160001 with overhead valves. Thanks.
lucass
11-21-2004 13:34:36
if you post the model number you may get an answer.tec made a few different 14hp type engines
grandfield
11-21-2004 17:16:56
 Re: 14 Horse Tecumseh Engine in reply to lucass, 11-21-2004 13:34:36
Where are you located? I'm in EXT NE Illinois, have some Bolens including the one you're working on, like to get rid of them. Thanks, grandfiedfarm1@aol.com
