cub cadet 102
A Cosh
12-02-2004 17:57:10
On the ignition coil which is towards the front of tractor the neg. or the pos. terminal ? On the Magnetic switch which the is top and /or bottom of this. Brass terminal up or down ?
Gregg
12-03-2004 03:45:20
 Re: cub cadet 102 in reply to A Cosh, 12-02-2004 17:57:10
On a Kohler engine the neg on the ign. coil goes to the points and condenser.if not you will invert the spark at the plug.
R Bedell
12-03-2004 02:47:25
It does NOT matter which way the terminals are orientated on either the Ignition Coil or Starter Solenoid. The more important thing, is that the correct wires going to these devices is installed properly.
ACosh
12-03-2004 03:20:12
 Re: cub cadet 102 in reply to R Bedell, 12-03-2004 02:47:25
Im following a wireing diagram and I cant tell which is + or -- from it. This why Im asking .
R Bedell
12-03-2004 03:55:10
 Re: cub cadet 102 in reply to ACosh, 12-03-2004 03:20:12
The wire from the battery (or positive source) (through the ignition or key switch) goes to the (+) Ignition Coil Terminal. The Points and condensor are connected to the (-) Ignition Coil Terminal.
On the Starter Solenoid, the ground is picked up via being mounted to chassis ground. The (+) wire is connected to the small solenoid terminal which comes from the (S) terminal from your Key Switch.
