Float settings 7hp BS vertical shaft
George Horel
05-07-1999 16:41:30
Does anyone out there have the float settings and possibly initial jet settings for a 7hp Briggs on a YardMan ride on mower Thanks Muchly in advance
karl brandt
05-08-1999 17:29:31
 Re: Float settings 7hp BS vertical shaft in reply to George Horel, 05-07-1999 16:41:30
The float should be parallel to the body mounting surface.Turn both idle and high speed needles in until they just bottom.Then turn both needle valves 1 1/2 turns open.Once started adjust needle valves.
