new holland ariens S14 models
carl holmstrom
12-09-2004 10:18:08
need help please, are the new holland & ariens S14 MODEL LAWN & GARDEN TRACTORS one in the same.also who would have used parts laying around.i can"t find any information on these tractors, i have a new holland ,i thing a 1971
Matt Yonkers
02-19-2008 07:03:16
 Re: new holland ariens S14 models in reply to carl holmstrom, 12-09-2004 10:18:08
I have a S-16 and have had a few minor troubles with it. I love the tractor though it is a very strong tractor. I have the mower, blower, and blade for it. I got a parts manual to help locate parts it is for the S-12 through S-16 with all the attachments, New Holland part ## 05001292. I got it from a New Holland Dealer for about $30 brand new.
Jamie Hurd
01-24-2008 11:50:58
I have a New Holland s-14.While removing the engine for rebuild, I found that the steering gears were badly worn. Where can I locate new gears. Thanks Jamie
casey rost
07-25-2005 07:45:19
We also have a S14 and are wondering if you've had any luck. We are looking for repairs for the tiller at this point.
Genoany
12-13-2004 19:16:35
I have a snowblower for sale in the classifieds if your are interested?
Look under NY state adds.
johnpop1
12-10-2004 16:28:04
The New Holland S-12 and S-14 preceeded the Ariens tractors. New Holland at the time was developing a line of lawn and garden and leisure products. After 2-3 years in the early 70's, New holland sold the line to Ariens. The two tractor lines are similar but have some major differences. At the time, New Holland was owned by the Sperry Corporation and used a Sperry-Vickers hydrostatic transmission. After the tractors became Ariens, a different transmission was used. The fender were changed from fibreglas to steel and so was the hood. The steering was changed from tilt to fixed and the steering gearbox was also changed. Both were ahead of their time and would be good for general use. I had both a S-12 and a S-14 that I had sold when new and re-purchased later.
Franklin E. Williams
06-16-2007 22:10:19
 Re: new holland ariens S14 models in reply to johnpop1, 12-10-2004 16:28:04
I also have a New Holland S-14 that I finally gave up on for a couple or reasons:
1. It kept blowing the front seal in the tramsmission.
2. I blew the cup seals in the hydralic control. I tried every hydralic shop within a 50 mile radius, and no one has them.
An unrelated note. My original drive shaft was one piece, and broke from vibration. They replaced it with a two piece, connected by a leather universal joint.
JT
12-10-2004 09:02:19
Ariens did build that tractor for Ford/NH, I am a dealer for Ariens, so if I can help you on naything, give me a shout. Most all the parts for this tractor should still be available from Ariens.
Jim
PA parts
12-09-2004 20:12:25
I've got a couple of these in the "yard" . Let me know what you need exactly. The New Hollands are basically the same- some minor differences but most any parts will interchange . They were built by Ariens for New Holland contrary to popular believe that Ariens bought N.H. out.
chadtoolio
12-09-2004 16:08:19
Carl,
Ariens bought that line of tractors from New Holland i believe. I have multiple pieces of equipment myself... What do you want to know and you might want to post it here:
Chad
carl holmstrom
12-09-2004 17:26:26
 Re: new holland ariens S14 models in reply to chadtoolio, 12-09-2004 16:08:19
i just got this tractor and quickly seen i have a very heavy duty tractor.i would like to put a snowblower on it.but the front axles are bad and i can"t find any parts for this tractor
Lo zampno
12-10-2004 04:08:05
 Re: new holland ariens S14 models in reply to carl holmstrom, 12-09-2004 17:26:26
Hi Carl, There was just a s14 tractor on ebay it was being sold as a parts ractor. You might want to check that out. There are some very knolageable guts on the ariens power equipment club on yaho groups. You might want to go there and join the group. Wellm the two tractors are the same except the color and a tlt wheel. Lou
