Snapper 360LTST snow blower...what oil for it's ge
AJMBLAZER
12-10-2004 20:37:16
The Snapper manual I got just says the level it should be at and how to check it. No mention of what oil should be in the snow blower's gear box.
For clarification purposes it's the gear box that the pto-shaft goes into and the auger shafts go out of in the center of the blower.
Vern-MI
12-11-2004 14:37:55
 Re: Snapper 360LTST snow blower...what oil for it' in reply to AJMBLAZER, 12-10-2004 20:37:16
Try this source for 1 quart bottles at $7.55 ea.:
Kent of SW MO
12-11-2004 09:23:17
Most any small engine shop will have "00" grease.
Kent
Dannie
12-11-2004 01:21:41
Snapper OO GREASE
AJMBLAZER
12-11-2004 04:45:28
 Re: Snapper 360LTST snow blower...what oil for it' in reply to Dannie, 12-11-2004 01:21:41
Anything else I could use? Gear oil?
The local place that I get my parts from doesn't seem to have that stuff or know where to get it.
Ludwig
12-11-2004 06:56:57
 Re: Snapper 360LTST snow blower...what oil for it' in reply to AJMBLAZER, 12-11-2004 04:45:28
Probably doesn't matter that much as long as it doesn't leak out or stay to thick to lubricate well.
This is the gearbox at the augers? You probably don't have to worry much about that getting hot... Maybe try some gear oil. Run 'er a little while and see if it gets hot or leaks, if it does put a little grease in.
