Found valve (wheelhorse GT14), but have no power, pressure.
Jeff Douglas
10-21-1998 17:41:45
1970 WheelHorse GT14
I replaced the check/relief valve on the pump that was damaged, but I am still not getting any power. Here are the symptoms, any help is apprecitated:
- Fluid level is ok
- tow valve is in correct position
- I can turn the pump pulley by hand easily, very little resistance
- one of the hydraulic lines going to the lift is soft, - the spring and spring seat in the check valve that was damaged were chewed up pretty good. maybe some of the pieces lodged somewhere else and did other damage?
Thanks again to anyone who might be familiar with this problem.
