5 HP briggs straton
allan sharog
05-08-1999 19:37:53
My connecting rod broke and the intake valve also was bend. I replaced both and ended up with 25 lbs of compression. I repositioned the rings and still ended up with 25 lbs of compression. Should I replace the rings and hone the cyclinder wall or do you have any other suggestions. Thanks, AL in Conn.
steve snowball
04-14-2001 11:33:09
 Re: 5 HP briggs straton in reply to allan sharog, 05-08-1999 19:37:53
ive got a 5horse that gets no spark could somebody help me out thanx
Tony
06-06-2002 06:25:12
 Hydro fluid in reply to allan sharog, 05-08-1999 19:37:53
michael bauch
02-15-2000 15:23:36
how do you fix a carburator
Bob Johnson
05-17-2002 10:49:37
 Re: Re: 5 HP briggs straton in reply to michael bauch , 02-15-2000 15:23:36
Looking for diagram or something similar to show correct linkage hookups for throttle to carburator ect. Have 1973 Ariens riding mower, engine # vm80-150040A
Gordie
02-15-2000 18:15:42
you may have a carb that has a needle in your main jet intake.shake your carb holding float ,LISTEN FOR A SMALL RATTLE IN SHAFT WEAR FLOAT BOAL SCREWS ON.THIS IS FOR YOUR SLOW IDLE SPEED.
Gordie
02-15-2000 18:15:19
Matt
11-14-1999 20:18:29
try replacing the gasket you may be loosing compresion through the head
Matt
11-14-1999 20:17:58
