102 Cadet
A Cosh
12-28-2004 11:35:40
The 1st & reverse gears . It wont go into reverse it just will grind. It works a little if the idle is low and I hold the lever down . 1st works as long as Im not pulling anything. If Ipull the wagon around with a little in it will pop out.
ANON
12-28-2004 16:35:47
 Re: 102 Cadet in reply to A Cosh, 12-28-2004 11:35:40
Take the fenders and seat bracket off and pull the shifter out. Either the shift fork is broken (which is now out of production) or you may have chipped teeth on the sliding gear. There are all kinds of parts on ebay for you.
ACosh
12-29-2004 13:43:34
 Re: 102 Cadet in reply to ANON, 12-28-2004 16:35:47
I pulled the shift ever off and the bolt on the rihgt side was loose. I tightened it up and it works fine. Thanks for the info.
