cub snowplow
Abram
01-07-2005 16:37:09
HI
ive got a cub 106 and i need to know where do you hang the front of the plow on the tractor. it has 2 pins and i cant figure out where they go on the front of the tractor. weve got piles of snow and i need to plow it.
ANON
01-09-2005 12:25:56
 Re: cub snowplow in reply to Abram, 01-07-2005 16:37:09
Abram, remove the front pulley drive from the frame by lifting the little handle under the grille. Line up the pins into the slots the pulley's came out of and latch the handle down. Make sure the rear of the snowplow subframe go against the lift handle cross shaft under the tractor.
Abram
01-15-2005 09:26:37
 Re: cub snowplow in reply to ANON, 01-09-2005 12:25:56
we actually bought this plow at a John Deer dealer and they had taken it off of a cub cadet 129. would that make a difference or should it still fit?
JT
01-08-2005 10:05:25
post thsi question at www.ihregistry.com
Cub sight, very good sight.
