What do I really have?
Adam Mongold
02-06-2005 07:30:49
I just got an old cub cadet and I believe it is a 1962 or 63 model 70. It has the kohler model #K161s motor. From what I found that was only available in the early model 70"s. But the serial # on the trans axle is 351350 R7 stamped upside down. According to the cub web sites that means it is a 1970 model. It looks exactly like the picture of the first model 70"s and looks nothing like the ones made in 1970. Am i reading the serial number wrong or what. If anyone could help I would be truly indebted to you. This is my first restoration. By the way I got the tractor for $50 and it runs and drives and has the original tires on it...sweet!!! thanks for your help
R Bedell
02-06-2005 10:38:16
 Re: What do I really have? in reply to Adam Mongold, 02-06-2005 07:30:49
Here is the S/N Range for the model 70: 70 - S/N: 65458 TO 127160 Built: 8/1963 TO 8/1965 Here is a link to see where you can locate your S/N: Link
ANON
02-06-2005 07:35:21
You are reading the casting number on the housing. Look on top of the housing above the rear cover for a stamped in number. All the 70 models had the 7 HP K161 engine. The K181 8 HP was not installed until the model 86.
ANON
02-06-2005 17:20:32
 Re: What do I really have? in reply to ANON, 02-06-2005 07:35:21
Just checked an older 70 I have sitting out here and the serial number is on the right side of the trans case, stamped on the front cover of the trans.
