cub 106 transmission
Abram
02-14-2005 09:49:38
i have 2 problems with my 106 cub. both of these problems happen only in 3rd gear. the first is when i put it in 3rd gear i can let out the clutch instantly and it will sit there for a second then very slowly start to move. and when i go up a hill it will start to slow down. the 2nd problem is when im driving in third gear it will just pop out of gear. it seems like its doing this more and more often. Thanks for your help.
ANON
02-14-2005 16:02:53
 Re: cub 106 transmission in reply to Abram, 02-14-2005 09:49:38
First, check to see that the throwout bearing is moving free on the driveshaft (lube it once in a while),then check the teasing spring to make sure it's not broken and jamming the clutch.As for the jumping you will have to remove the fenders then the shifter cover and check the 2nd-3rd shift fork. Make sure the fork is not broken and is tight on the shift rail.
