11 hp Briggs Stratton has knock but rod looks see
Brad in SW MO
03-13-2005 19:23:42
I have a Briggs 11 hp motor that stars and runs fine but makes a loud knocking noise. I pulled the bottom cover off but can"t find any slack in the rod at all. Is there anything else that could cause the noise? Any help is greatly appreciated. Thanks.
don watts
03-16-2005 14:57:35
 Re: 11 hp Briggs Stratton has knock but rod looks in reply to Brad in SW MO, 03-13-2005 19:23:42
when i worked in the field repairin tractors if that engine pulley is worked loose from the bolt either not bein tight or backin out will sound like a rod knockin .just a thought.don
bluediesel
03-14-2005 17:19:46
You may have done this already, but pull the head and make sure that the carbon build up is not too great. I"ve seen carbon hammered(like metal) in one spot(not that large)where the piston would " bang" the head. You would feel this between exhaust and intake stroke, up at T.D.C., but then again it could make noise even if you don"t feel it. Another thing we had trouble with was the cam gear on the crank. They got loose and hammered. Just my $.02. Bob, from Illinois
JT
03-14-2005 16:53:01
Is this an 11hp sybro-balanced engine? If it that style of engine, check the sybcro-balance and make sure the little tin bearings on the c/s are not worn and letting hammer there.
John McPherson
03-14-2005 07:20:21
Upper main bearing wear can cause some sounds similar to a connecting rod, also check the flywheel to see if it may have contacted the magneto at all, if it is loose, or the magneto shifted.
Also too, if there is excessive end play in the crank shaft, it can make that noise also. The end play is "adjusted" by using different thickness crankcase/base gaskets.
Kent of SW MO
03-14-2005 06:16:16
Brad,
Where are you in SW MO. I am North of Springfield.
Kent
Dannie
03-14-2005 02:16:26
Yes pistom or too much valve clearance.
