cub cadet 106
Abram
04-01-2005 17:06:47
i have 2 problems with my cub cadet 106. the first is when im stopped and im in third gear i let out the clutch and it will sit for a second then very slowly start to move. my second problem is when im driving in third gear it will pop out of gear by its self. and its been doing this quit often and its happening a lot more. how would you fix both these problems.
thanks
dvogtvpe
04-02-2005 17:05:21
 Re: cub cadet 106 in reply to Abram, 04-01-2005 17:06:47
first problem sounds like a clutch disc or clutch spring. fixing it involves pulling the engine. 2nd problem sounds like a shift fork, bad gear or a poppet spring broken for the shift denents .
