john deere 116 not charging
aaron from wis
04-08-2005 03:42:35
i have john deere 116 rider and is it not charging the battery anymore. i put a new diode in it thinking that was the problem. is the stator shot? wires all check out and are fine and going to the right place.evry thing else is working fine she just won't charge the battery while running and after awhile the electric clutch gives out no more juice. put battery charger on for awhile good to go again. thank you
aaron from wisconsin
04-09-2005 19:00:46
 Re: john deere 116 not charging in reply to aaron from wis, 04-08-2005 03:42:35
i would like to say thank you for your advice.but the tractor will be kept at a cottage with no electricty.so if any others could please help thank you
deereford
04-08-2005 19:35:53
I had one of those with the same problem. JD told me that it was a common problem and replacing the stator didn't solve the problems. I sold mine but I was thinking about mounting a automatic charger on the chassis and just plugging it in when I finished mowing to keep the battery charged. good luck, deereford
