A 1872 cub cadet
mikey846
04-08-2005 06:10:10
do they make a rebuild kit for the relief valves in the hydraulic pump?cause they cost 108 a piece thanks
KennyW in CT
04-08-2005 08:38:03
 Re: A 1872 cub cadet in reply to mikey846, 04-08-2005 06:10:10
No kit that I know of, I use # 016 and # 116 O-rings and reuse the nylon backup rings. Clean everything good in acetone then reassemble with new o-rings and soak the valves in Hytran before re-assembly. Kenny
mikey846
04-08-2005 11:01:49
 Re: A 1872 cub cadet in reply to KennyW in CT, 04-08-2005 08:38:03
what if its still leaking after all that ?? is the valve shot then. ok thank you for your reply
KennyW in Ct
04-08-2005 11:13:23
 Re: A 1872 cub cadet in reply to mikey846, 04-08-2005 11:01:49
Afraid so, the older button style relief valves were more friendly to cleaning and rebuilding. The newer self relieving types(with just the pinhole on top)are hard to clean. Kenny
