BS engine questions
Dale(MO)
04-10-2005 18:01:34
I hope someone can help answer a stupid question or two. After 15+ years of turning wrenches on gas and diesels in trucks and heavy equipment, I have NEVER messed with a Briggs engine. I have a 3hp. on a Toro tiller - model# 80292, type# 0582-01, code# 75021003. It has no fire. My question is: Would this be point-type ignition, or solid state? If point-type, how do I get to the points and condenser? If solid state, does it have a condenser, and where do I access it? I hate to just tear into it blind, I know how my luck runs. Thanks.
Dale(MO)
04-11-2005 11:57:37
 Re:Thanks!!!! in reply to Dale(MO), 04-10-2005 18:01:34
Thanks to everyone who replied, you were all great!
This morning I pulled the flywheel, put in the points and condenser, and got it running. Took about 20 minutes. In all my years of fooling with junk, this was the first time I ever saw a Briggs torn down.
I guess you're never too old to learn.
Again, thanks, and good luck to all!
don watts
04-11-2005 15:23:25
 Re:Thanks!!!! in reply to Dale(MO), 04-11-2005 11:57:37
you didnt think you were gonna get out of cutting the grass that easy did you good deal.
Dale(MO)
04-12-2005 03:03:13
 Re:Thanks!!!! in reply to don watts, 04-11-2005 15:23:25
Don,
Unfortunately, it's on a tiller. If only I could get the wife to run it - I told her that I would start it for her, and help her eat the veggies! I think I may have to come up with a better plan.LOL
Thanks again!
Dale
hlc
04-11-2005 11:32:04
 Re: BS engine questions in reply to Dale(MO), 04-10-2005 18:01:34
Why convert to electronic if points/condenser is so cheap? The coil will be ok as is.
(1) Remove the nut or starter ratchet holding the flywheel dow.
(2) With a small crowbar or molding puller put some upward preasure from underneath the flywheel.
(3) With a hammer slightly hit the top of the shaft and the flywheel will pop off. Normally the top is covered with a special cover or tool to prevent damage to the shaft. Take notice of the flywheel key and if it is dented replace.
(4) Lightly sand the flywheel magnet and the contact at the coil if they are rusty.
maricopa
04-10-2005 20:32:40
Dale,
The cheap way would be to get rid of the points and condensor and add omega electronic module with your existing coil instead of whole coil. Around $10.00 or so for the module instead of 40-50 for a magnetron. Also some may call it the atom.
Chad
04-10-2005 19:06:20
It is a 1975 year and it will be points type if it is original. The points are under the flywheel. If you plan on keeping it I would get a new solid state coil with the electronic ignition built in and be done with it. You only have to remove old coil and install the new one. About 40-45 dollars.
Dale(MO)
04-10-2005 19:30:49
 Re: BS engine questions in reply to Chad, 04-10-2005 19:06:20
Chad,
Thanks for the info. How do you go about pulling the flywheel? Sorry for all the questions, but I appreciate the info. Thanks!
don watts
04-10-2005 20:39:58
 Re: BS engine questions in reply to Dale(MO), 04-10-2005 19:30:49
dale if you dont have a flywheel puller for briggs you can use a wheel puller.loosen the flywheel nut and put the wheel puller fingers under each side of flywheel.tension it up tightly but not so tight that you damage the ring gear on the flywheel.give the wheel puller a sharp blow and the flywheel should pop up .if it dosent go get a briggs flywheel puller to keep from damaging the fly wheel.points coil and cond are under there.good luck .hope that helps
Dale(MO)
04-11-2005 02:10:03
 Re: BS engine questions in reply to don watts, 04-10-2005 20:39:58
Thanks to all for the replies. Knowledge is power, even if it's for small engines!
Dale
Kent of SW MO
04-11-2005 06:54:07
 Re: BS engine questions in reply to Dale(MO), 04-11-2005 02:10:03
Dale,
The recoil starter clutch is ALSO the flywheel nut. Remove as an assembly DO NOT take apart and loose the little balls.
Kent
