I have a Dynamark ride on mower with a 12 volt electric start and i had the very same problem. Witht he lid tipped up, i can look dfown into engine and on the right hand side there is a cable coming our fomr under engine cover which i assume is fomr coil of engine it has a sapde termianl on it that should have a black wire fomr the ignitoin switch taht when the key is in off pistion will ground out the coil by the wire hooked up to this spade connection. one way u can test this theroy would be to take a wire form neg termial of battery and put it on this terminal on side of engine, it sould ground it out and make engine stop i catuoi u shold do this with engine running but switch in off position so u are nto shroting out other things at the same time if this shuts down engine u know the source of your problem and acna then tracae wire fromkey switch to this termial on engine, hook it up and it sould slove your problem best wishes Pat
