682 electric clutch
IA Roy
04-16-2005 19:22:55
I recently bought a Cub Cadet 682. When I try to turn the pulley (with the engine off) for the clutch output, there is a dragging feel and sound. Could it be out of adjustment? Could the bearings in the clutch be bad? When I engage it, the mower has what sounds like bearing noise. I had the deck off and the spindles feel smooth when turning. It seems that if the bearings in the clutch were bad, it would make noise when the clutch were disengaged instead of engaged. Any ideas?
R Bedell
04-17-2005 05:02:47
 Re: 682 electric clutch in reply to IA Roy, 04-16-2005 19:22:55
When the Electric PTO Clutch is disengaged, it comes to rest on the Brake Portion of the clutch.
It would be normal to see resistance and a grinding noise if rotating the pulley by hand.
There is an adjustment to the Electric PTO. It is outlined in the Owners Manual (772-3038) and the Chassis Service Manual (GSS-1497). I would suggest, that if you don't have these manuals, that you acquire them. They are available from Cub Cadet (www.cubcadet.com), any Cub Cadet Dealer, some Case-IH dealers, and numerous Cub Cadet Dealer Web Sites.
The bearing noise you hear could be from any of these three areas. (A) The electric PTO clutch, (B) the mule drive pulleys, and (C) the deck spindles. You will have to use the process of elimination to narrow this down.
The Clutch Bearing can be check by simply engaging the clutch with no belt on the pulley and listen for noise. A better and more accurate way would be to remove the clutch and do a thorough inspection - (GSS-1497) would highly be recommended for this.
The Mule Drive and deck spindles can be checked by feeling for roughness.
Bob
04-16-2005 21:12:44
The electric clutches are often set up so when they're shut off, and the plate returns from the engaged position, it contacts another plate that acts as a brake, to stop the mower quickly.
