110 no start
chrisfromsolitude
04-18-2005 11:20:15
I have a 1966 110 with a starter generator. The gen light comes on sometimes when you mow. It was starting fine last time I used it and I went to start it yesterday and nothing happens. The gen light comes on but the generator won't spin over. The light doesn't go out when you turn the key to start position. Any ides where to start? Thanks for the advice and have a nice day.
michael kaus
04-18-2005 16:12:01
 Re: 110 no start in reply to chrisfromsolitude, 04-18-2005 11:20:15
Ignition switch and get it started then check gen output. If running and only get 12v(or less) at the battery, gen circuit is no goodsky. Then you have to find out if it's regulator or generator itself. THe fact that it's not starting and the light doesn't dim or go out means there is no load so I'm betting the generator is brushless and will have to be repaired/replaced.
