455 remote hydraulics
Bob in Ga
04-18-2005 14:10:23
A couple questions for you:
How can you loosen up the remotes lever on the column. My newly purchased one is stuck. Manual says to move it occasionally, and I would say that the previous owner did not.
My tractor is equipped with small pioneer hydraulic fittings. Does anybody know what size these are? I would like to get adapters so I can use some of my big tractor equipment with it.(Hydraulic motors etc.)
Mike H (Md)
04-21-2005 10:42:11
 Re: 455 remote hydraulics in reply to Bob in Ga, 04-18-2005 14:10:23
Go down under the tractor and spray the hydrolic control rods with wd40. If rod is jammed in use a small prybay and put pressure on to move out and gently tap with a small hammer until it comes out. If stuck out have someone keep pressure on the lever and tap in. Keep moveing and spraying until free. Helps to have the deck off while doing this
