Ariens 18 with Kohler 18 HP Magnum Engine
RMP11
04-19-2005 09:42:25
Does anyone know how to rebuild the carburetor for this engine? I accidently tried to run 2cycle gas and now I cant run except with the choke on.
Please help
Dannie
04-20-2005 01:48:32
 Re: Ariens 18 with Kohler 18 HP Magnum Engine in reply to RMP11, 04-19-2005 09:42:25
2 cycle gas should not hurt engine.I use up mix gas in all my mowers & tractors.After 4 weeks I mix new gas and old mix goes in mower.If rich mix your plug may need changed.Good Luck
old art
04-19-2005 20:40:09
change the fuef filter and clean the tank also take the carb. off take the float bowl off and remove the float and needle valve and blow back through the fuel inlet put back togeather and try it . dont lose any of the snall parts
