HELP: Huski Bolens
A.Brooks
04-19-2005 18:51:13
I read a post about old Bolens 2 wheel tractors. I have my Great grandfather tractor. and this thing is a beast. The S/N is G5894 With a Port Washington Wis. tage that says Huski. I have the cicle mover and 3 other attchments. I would like to know anymore info on it you all have. And a question for the road. My fahte rand i are trying to take the flywheel off so we can replace teh sparkpulg whire, we cant get the other side to stop that runs the mower do get the bolt off of the flywheelb/c we are shad tree machanics. ANY information would be a great help. Yall ahve forgotten more than ill ever learn im only 15 . Once again gentament thank you.
don watts
04-19-2005 19:18:17
 Re: HELP: Huski Bolens in reply to A.Brooks, 04-19-2005 18:51:13
you really need to use a flywheel puller.but if u dont have one u can use a puller with fingers on each side.insert the fingers under the flywheel and snug the bolt up just so it has tension on the flywheel.tell your father to check the fingers to make sure there not damaging the ring gear on the flywheel.tension the bolt up snug.then give the bolt a sharp blow not hard because u can knock the magnets in the flywheel loose.give it a sharp blow and then see if flywheel will pop off.when u get the flywheel off make sure u chk the magnets inside the flywheel to make sure none are loose.
Bob
04-19-2005 19:08:56
Here's a site that has often been posted before. I have no connection with them, and have never dealt with them.
