12 hp b s
b plotts
04-20-2005 04:59:46
engine will run. won't start with mower bat, have to jump from truck bat. motor will turn easy for about 3/4 turn then seems to bind up. have checked timing ok. havn't checked valves. have any ideas thanks bill
jed1950
04-20-2005 13:07:15
 Re: 12 hp b s in reply to b plotts, 04-20-2005 04:59:46
check your valves thenI would check the starter motor,it may be the problem,should not need to use larger battery to start,
Bob
04-20-2005 12:59:20
Check the valve adjustment on the engine, and if that's OK, get the biggest cranking amps garden tractor battery you can find.
They are made in a number of sizes, and you may have on that's too small, or is worn out.
