Toro rottotiller part needed
1barron
05-03-2005 06:19:09
Can anyone help me locate the bronze gear for an old Toro rototiller. The gear is in the transmision that powers the tines. the model number is 58210201450
Thamks Carl
hlc
05-03-2005 17:24:46
 Re: Toro rottotiller part needed in reply to 1barron, 05-03-2005 06:19:09
I have one of those torro tillers with the big brass gear. Mine chew up and I replaced it at and at that time it cost $50. I ran one hour and the new one chewed up. Next time I also replaced the worm gear that meshed with it and also some bearins and just about everything connected. It lasted that time. Just warning you....
Wheel Horse
05-03-2005 13:20:00
The model number probably is 58210 which is a 1972 26" tiller, correct? Is it the worm gear that is in the round housing extending in front of the engine plate? That is part number 7-0016 if that is the correct part. According to www.rcpw.com, it is available and is around $87. Might go to the following site and put in the model number above to look at the parts drawing...
https://lookup2.toro.com/partdex/index.cfm?xCaller=Toro
