Bolens verse a matic
Ryan
05-27-1999 18:39:35
Does anyone know what years these were produced
and the value of one??? I just had one given to me not running, cleaned the pionts and she fired up!!! Has a good mower deck, a siezed snow thrower, partially siezed rototiller,and a push plow. also need to find parts to fix the siezed stuff....thanks for the help
dan soos
02-23-2003 09:35:53
 Re: bolens verse a matic in reply to Ryan, 05-27-1999 18:39:35
i have a bolens vers a matic it is in perfect condision i also have the manual. bolens verse a matic was built in 1945 coming with a drag plow, drag disc, & a drag culivator. optional atachments were snow plow front, mower front, sicle bar fornt, ride behind seet, and snow blower. hood covers were bolens green with yellow painted decals. handles and wheel weights were also yellow.
steve from mo
05-27-1999 18:47:50
I don't know years made, value, or where to go and find a Bolens dealer. Someone else here may know. In general you have to disassemble the siezed parts and find out if there was a bearing or if it is just steel-to-steel and rusted tight. If it is rusted you obviously just clean it up, oil it, and go. If there is a bearing, you get the old one out however you can while trying to save the bearing parts so you can take them to your local bearing dealer. You will need the outer race or shell and the inner race. That way, even if you can't get the same brand of bearing you can usually get the same type and size. Again, reassemble and go.
Good luck.
