6.0 horse gold briggs (leaking gas)
Bilko
05-15-2005 12:37:38
I have a craftsman push mower with 6.0horse gold briggs on it and it started to leak gas from the primer button and out the air filter. I have no idea why it is doing it. Does anyone know how to fix the problem. Any help would be appreciated. Thanks Mike
don watts
05-15-2005 18:26:21
 Re: 6.0 horse gold briggs (leaking gas) in reply to Bilko, 05-15-2005 12:37:38
if you keep pushing on that primer bulb it will eventually flood and cause the gas to run out of the end of carb.now if its leakin out from the carb on its own it sounds like the the float inside the carb bowl is not coming up shuttin off the flow of gas.need to look in the bowl and see if theres trash in it or dirt or possibly the float itself has a hole in it.om the primer if itsleakin out of there more than likely the primer bulb has a pinhole in it.chk that out and good luck.
