14 horse Kohler wont idle
Dave Sherburne,
05-22-2005 11:20:46
Have a 14 horse Kohler in a Power King that won"t
idle. Tractor hadn"t run in several years when I
got it. Any fuel that was in the carb or tank had
evaporated. I soaked the carb in Lacquer thinner
for three days and then blew it all out and put it back together and it started right up. Probrobly
still dirty, but has anyone got another idea????
KennyW in CT
05-22-2005 13:54:35
 Re: 14 horse Kohler wont idle in reply to Dave Sherburne,NY, 05-22-2005 11:20:46
Check for a vacuum leak at the carb flange, also check the idle fuel bleed passage for a blockage. To check the bleed passage properly will require a 5/16 welch plug. Is it a Carter Model N #30 or a Walbro? Kenny
