Kohler K321S- pingimg/knocking sound under load??
aconway
05-22-2005 19:30:06
Can anyone tell me what I may look for or change on this? Its on a Bobcat 371. It runs good, but seems like it may be heating up a little more than it should. I changed the oil recently also.
It has a new muffler from Bobcat also. I did adjust the carb and the throttle cable as well so it would idle good and rev up correctly.
I was wondering if the gas I am using is to low in Octane..
If anyone can give me some ideas I'd appreciate it. Thanks!
mowr
05-24-2005 20:54:14
 Re: Kohler K321S- pingimg/knocking sound under loa in reply to aconway, 05-22-2005 19:30:06
Fresh, regular gas should have plenty of octane. If, however, the gas you're using is old or contaminated with kerosene or diesel, it can cause your problems; too low octane.
mowr
05-23-2005 20:32:42
If the carb is adjusted for revs, it will run too lean under load. If adjusted properly for the load, it will seem a little rich at high rpm. Too thin oil causes problems. Above 32 degrees, the lowest number on the oil can needs to be 30W.
Dannie
05-23-2005 00:46:54
Could have carbon build up in cylinder.
lucasss
05-23-2005 05:52:45
 Re: Kohler K321S- pingimg/knocking sound under loa in reply to Dannie, 05-23-2005 00:46:54
try setting the points with timing light according to the manual. lucas
