JD STX 38 won't start
Al L. in Wisc.
05-24-2005 11:51:20
Still unable to get it started. Can/could I just eliminate all wires to the key switch except a ground and hot (runs to solenoid) and cut off the other wires to OSHA seat/clutch/brake? Manual tranny on this one. I"m so dumb at this. Thanks is advance.
benito cortina
05-27-2005 13:46:29
 Re: JD STX 38 won't start in reply to Al L. in Wisc., 05-24-2005 11:51:20
Had the same problem on mine. Bought the coil and now it starts right up. Had spark but was very weak. First check intensity of your spark. Also make sure you or someone is sitting with the clutch in. make sure you hear a click on your solenoid.
