Battery/Charging Problem
Mario M.
05-27-2005 09:01:22
I hope someone can help, I have a John Deere 165 garden tractor which when I am cutting the grass with the cutting deck engaged the battery losses power after an hour or so. If I put a full charged battery in it works fine & if I disconnect the battery the motor still runs,but the deck stops. The motor will run all day long without a battery. I did a voltage test at the battery post with motor running & the reading was the same without motor running. Then I started the motor & disconnected the battery & did the same test at the cables the voltage reading went up & down with motor speed, but I was reading it with a pos.(+) ground. This is what I don't understand; the neg.(-) ground changed to pos.(+) ground.
stronics
05-28-2005 13:54:31
 Re: Battery/Charging Problem in reply to Mario M., 05-27-2005 09:01:22
Mario,
As I think Bob says check the outer wires coming from the engine with a multi-meter set on AC. It should read 25-34 volts if the stator is good. This test does not hurt the stator. If that is in the range make sure the regulator is grounded really good, take it off and clean the area it sets on and itself.
Then check at the battery again. If not in the range we talked about it is the regulator.
David
stronics
05-28-2005 05:10:11
Mario,
That is not enough voltage to keep the battery up for sure. With the engine running pretty fast without the deck on it should be about 13.8-14.5.
Two things could be happening.
Battery going bad sucking up the charge or the diode breaking down. Usually they just go out though and won't charge.
Easist way, do you have an exchange battery you could try? If same condition exist then the diode or the alternator is bad.
David
Mario M.
05-28-2005 06:17:44
 Re: Battery/Charging Problem in reply to stronics, 05-28-2005 05:10:11
David I do not beleive it is the battery becuase I have been useing two batteries to cut my lawn, when one runs out I replace it with full charged one. Is there any sure fire way to test if it is the regulator or alternator. I would hate to change the regulator & then find out it was the alternator. The electronic parts are not returnable. (regulator around $100)
stronics
05-27-2005 17:09:23
Mario,
With the pto off and the engine running what is the voltage at the battery?
Now with the deck on what does it read?
If it drops below 12.6 the electric clutch it draining the battery. Let us know.
David
Mario M.
05-27-2005 17:41:10
 Re: Battery/Charging Problem in reply to stronics, 05-27-2005 17:09:23
Hi stronics, The voltage at the battery engine running it reads 12.62 & I understand it should read around 14.5. With deck on it drops to 12.36& the longer it runs with deck on the lower voltage gets. Like said in my first message I took a reading without the battery & the voltage went up & down with the speed of the motor. Found out thats a NO NO!
Bob
05-27-2005 11:18:09
It is NEVER a good idea to troubleshoot ANY alternator system by disconnecting the battery, and removing the load from the alternator.
Have you checked the 20 Amp fuse in the harness near the regulator?
The reversed polarity reading you are getting could very well indicate a bad diode in the rectifier/voltage regulator unit, but you can't necessarily rely on any voltage reading made with no battery load on the regulator.
Regulator is part #M97348, @ $100.00.
Mario M.
05-27-2005 15:11:27
 Re: Battery/Charging Problem in reply to Bob, 05-27-2005 11:18:09
One more thing Bob, I have three wires coming from the motor which I believe are coming from the alternator, two are black & one green . The green one seems to be a ground wire. How would I check power from the alternator safely.
Thanx
jake3
05-28-2005 08:33:59
 Re: Battery/Charging Problem in reply to Mario M., 05-27-2005 15:11:27
The stator windings can be tested by the use of a volt meter set for AC. The output will in the 25V range. In most cases the 2 reds will connected to the regulator converting into DC 14.5 V, the green should be the kill. Which engine is used might be able find a diagram.
Mario M.
05-29-2005 08:53:17
 Re: Battery/Charging Problem in reply to jake3, 05-28-2005 08:33:59
jake3 the motor is a Kawasaki FB460V.
Thank You very much.
Mario M.
05-27-2005 14:28:49
Thanx Bob for the info. & advice, I am learn as I go. I checked for the fuse but could not find one. Bought the JD used & alot of the wiring looked like it was cut & repaired. I gess a wiring diagram would help. I did voltage reading at the battery post agan at start & then 1/2Hr later & reading was lower.
Agan Thank You
