445 Surging Problem
Keaton Mulvaney
05-28-2005 03:22:58
Surging problem occuring before cam gear failure. Replaced the plastic geared camshaft, tappets and damaged water pump drive gear. Performed general check of engine, compression, spark (found one coil to be bad, replaced), etc. Engine runs again and has power but surges at idle and at different speeds. Anyone experienced with the fuel injection circuit on a 445? Any help or suggestions would be greatly appreciated.
Keaton Mulvaney
06-03-2005 20:16:08
 Re: 445 Surging Problem in reply to Keaton Mulvaney, 05-28-2005 03:22:58
Upon very close inspection of the fuel pump/float assembly, I found a small slit in the hose connecting the output end of the pump to the hard piping that exits the top of the tank. Replacing the hose and two clamps solved the problem.
