BS Vanguard question
Rauville
05-29-2005 09:07:03
I just took delivery of a new (0 hr.) Simplicity Citation ZTR with a 23 HP B&S "Big Block" Vanguard engine. I wasn't here yesterday, when the dealer dropped it off. In fact, the entire transaction took place over the phone...I never saw the mower or have yet to meet the dealer in person.
My question is: After reading the owner's manual and trying the mower in a practice trial; the engine runs rough and smokes black when moving the throttle up. After a few seconds, it clears up and smoothes out. Is this normal for a new engine? I checked the air cleaner, and the pre-cleaner is oil soaked to the point where oil is dripping off. Too much oil? The crankcase oil level is normal. I've also checked the choke and throttle assemblies, both appear as they should be.
Thanks
Rauville
05-31-2005 06:42:21
 Re: BS Vanguard question in reply to Rauville, 05-29-2005 09:07:03
Thanks everyone for your help and comments. I followed the BS engine manual instructions as to washing the pre-cleaner and not oiling it. With the foam PC installed dry the engine seems to run entirely normal. We tried it out yesterday for a couple of hours, and it worked great. Strong running engine...fantastic mowing machine, compared to our old one.
pdi man
05-30-2005 14:15:17
jt is correct. the pdi--pre delivery inspection, should have caught that. i work for deere dealer. that is why we do pdi. the way oily filter is causing the engine to run as if on choke. can"t breathe with all that oil in the way. sounds as though the block breather may be bad, allowing the oil to get upstairs. make the dealer fix it. at zero hours, not your responsibility. if you mess around too much, you will void that.
Stickler
05-30-2005 16:12:50
 Re: BS Vanguard question in reply to pdi man, 05-30-2005 14:15:17
Now that brings up a good one. Anyone know where the crankcase breather is located on the 18 horse?
JT
05-30-2005 13:36:28
Sounds as though you need to contact Mr. Dealer and have him fix it, you did not buy a new mower to have to work on it. What you are finding is part of the set up and delivery on a new mower and maybe was not done correctly. At least that is the way I do business.
Vern-MI
05-30-2005 03:09:29
How well does it run without the filter? Are the spark plugs fouled because of running with an oily air supply or from an oiled air cleaner restricted fuel rich mixture? Call the dealer and explain the problem and let them come and fix it. It is an expensive machine and it should be right at least for a few days when new.
Robin Barnard
05-29-2005 22:55:07
Sounds to melike he overoiled the filter but the black smoke and the way the engine was running indicates to me that the fuel mixture is a litle rich! Easiest way to remember or a good rule of thumb is white smoke oil,black smoke too much fuel, blue smoke rings!
later!!
Bob
05-29-2005 09:26:22
Don't know about that BIG engine, but I seem to remember Briggs cautions AGAINST oiling the outer air filter foam wrap on the smaller Vanguards. They are to be used DRY. Better find a manual for the Briggs that gives correct specifics, one way or the other.
Kent of SW MO
05-29-2005 17:16:54
 Re: BS Vanguard question in reply to Bob, 05-29-2005 09:26:22
The overwrap is ALWAYS oiled but you need only a tablespoon of oil at MOST to oil them. Without the oil they are of NO use on the filter. If there is a lot of oil the paper filter may be oil soaked and WILL need replacing.
Kent
JT
05-30-2005 13:33:26
 Re: BS Vanguard question in reply to Kent of SW MO, 05-29-2005 17:16:54
Kent,
A lot of the newer engines are using a dry prefilter. It is there to extend the life of the air filter by filtering out the big chunks before it gets to the paper filter. On the older style with the foam wrapped around the paper filter, you are correct, but these new ones with the foam and flat paer are all used dry. You are correct in that if the foam is overoiled to the point of driping, then both filters are ruined and need to be replaced.
Bob
05-30-2005 09:30:26
Kent,
I just checked the instructions for my 18HP Vanguard V-Twin. Manual says the foam pre-filter may be washed in soap and water, squeezed dry, and then re-intalled DRY... NO OIL.
Don't know what the proper procedure is for his 23 HP, but the it seems like the oil filter may be the problem!
Stickler
05-30-2005 12:44:04
 Re: BS Vanguard question in reply to Bob, 05-30-2005 09:30:26
I have an 18hp vanguard as well, and the manual for it also says the precleaner is left dry. if it is oiled, it acts like the choke is on. I just washed it yesterday.
Bob
05-30-2005 09:31:24
That should read OILY AIR FILTER, not OIL FILTER!
Bob
05-29-2005 22:13:32
Kent, are you SURE about that with the Vanguard twins???
Bob
05-29-2005 22:13:29
