BS 18hp Vanguard electric starter
Stickler
05-30-2005 12:55:34
Is there a trick to getting to the top bolt on this SOB? I did it once by dismantling the starter to gain room for a flex socket. Then I took the driveshaft and shrouds off, and found there still isn't enough room. If I ever have to take it off again, I think I'm gonna put an allen bolt in there so I can use a ball end allen key unless there's a better way. Maybe there's a fancy special wrench for this job? This is on a 718 Grasshopper. The frame's not in the way, but the cylinder on that side sure is!
