14.5 Briggs won't stay running.
Chris 44
06-04-2005 16:48:26
I have a 14.5 Briggs on a Craftsman that I cannot keep running. I've removed the filter and shot gas in from the top and it will run as long as I keep shooting a little in at a time, but the second I stop, it stops. The fuel is flowing freely to the carb, so I rebuilt it and that didn't work. I have now replaced the Nikki carb and still nothing. Very rarely it will turn over and run for a few seconds and die. Any help or ideas would be greatly appreciated...Thanks.
supergrumpy
06-05-2005 06:25:13
 Re: 14.5 Briggs won't stay running. in reply to Chris 44, 06-04-2005 16:48:26
does your carb have fuel cutoff solenoid??, probably at base of carb
make sure its getting voltage plus clicks and moves on/off
don watts
06-04-2005 19:23:54
chris have you tried some fresh gas.from what your describing it sounds like you may have a little water in the gas esp if its a new carb. don
