Bolens 1502 hydro
Bob
06-04-1999 19:20:58
A compact diesel by ISEKI.
Need to locate parts for the front PTO which was apparently mfg. by ISEKI also.
Calls to Garden Way are of NO USE.
Parts needed are listed as: V-Pulley, Rubber Joint and pin(8x34)
Any help is appreciated.
pete diehl
06-25-2006 14:57:53
 Re: Bolens 1502 hydro in reply to Bob, 06-04-1999 19:20:58
to remove the coupling you need to pull the spring back to depress the pin i have the pully assembly for this tractor i am currently looking for a radiator.
pete
05-16-2003 04:05:11
could someone please tell me how to remove the front pto to replace the belts.
BUD ADAMS
11-16-2003 15:40:54
 Re: Re: Bolens 1502 hydro in reply to pete, 05-16-2003 04:05:11
HELLO, WONDER IF YOU FOUND A WAY TO REMOVE THE PTO
ON THE ISEKI.... WOULD LIKE TO HERE FROM YOU,
THANKS
Bob
06-05-1999 18:39:00
Have purchased v-pulley and pin.
STLL NEED rubber joint.
Curtis Ainsworth
08-12-2002 18:03:47
 Re: Re: Bolens 1502 hydro in reply to Bob, 06-05-1999 18:39:00
Would you please advise me if you have found a source for the rubber mounted v-pulley? I have one that is useless and needs replacement.
Please email me direct .
Thanks,
Curtis
