5hp Briggs that wont start
beggsie12
06-15-2005 11:04:41
this is beggsie i cant get into my old name so i made a new one thanks a bunch to all of your updates on my last message the thing is i am only 15 and i have a limited spending amount and the part number that JT gave me on the Briggs website says it is a armeture magneto and i think that is what i have on ther i dont know but there is a wire that i dont know were it goese and i would like to know if any one knows were i can get a wireing diagram for this engine it is a 1976 Briggs and Stratton 4 stroke model number 130292 type 0709-01 if any one get tell me were to find a wireing diagram i would really appreciate this thanks
shannon from ohio
06-15-2005 17:56:08
 Re: 5hp Briggs that wont start in reply to beggsie12, 06-15-2005 11:04:41
First of all, on engines that old the points usually get a little crud on them from moisture,not your fault,just something you have to put up with and correct when it happens 2nd.. You can go to a salvage yard and get a Magnetron coil off an old worn out or blown engine (about 3 to 5 bucks)If you buy a new one it will cost about 25 to 40 bucks,Don't think so in my case.I'll bet i got about 30 of them from the salvage yard where i work.. 3rd DO NOT let them small engine techs tell you that you have to change the flywheel along with the Magnetron coil YOU DON'T NEED TO. I convert all my briggs to magnetron (electronic ignition).Hope this sheds a little light in your situation????
JT
06-16-2005 06:28:55
 Re: 5hp Briggs that wont start in reply to shannon from ohio, 06-15-2005 17:56:08
Shannon,
You are partially correct about changing flywheels with magnetron igntion. If you were to attempt to put a magnetron ignition on a cast iron engine that has points, you do have to either change the flywheel ot the polarity of the magnets in the flywheel. On the engines with a 3 legged coil, you cannot put magnetron ignition on tham at all.
Jim
JT
06-15-2005 16:44:32
Beggsie,
If you will email me I will tell you all the info you need to get this problem resolved. I will help you all I can, but on a tiller, if you do not have solid state ignition, it is the way to go, it sure makes them start easier, and you do not ever have to mess with points again. But, again, email me and I will explain to you what you need. Jim
DON WATTS
06-15-2005 15:43:57
beggsy mac is right .go to www.briggsandstratton.com and input that engine number.they have it in pdf format. good luck
Dorris Fugate
06-25-2005 04:24:52
 Cannot Find Id. Number To Order Manuals in reply to DON WATTS , 06-15-2005 15:43:57
I have a Briggs & Stratton Engine on a riding mower and need a manual.
The moter is suppost to be a 16.5 Hp.
The engine is not the original motor.
There are no ID numbers that I can find on the motor.
Is there any other way to determine what size the motor is so that I can order a repair manual?
hlc
06-15-2005 15:15:41
I would not advise you to buy the part you mentioned. Suggest you put new points and sand the magnet and amatuer contacts. Set the gap at .10. It is unusual for the coil system to go bad on these engines. Very few wires there that would require a wiring diagram. You are probably dealing with a kill switch wire.
beggsie12
06-15-2005 16:13:00
 Re: 5hp Briggs that wont start in reply to hlc, 06-15-2005 15:15:41
well the Briggs and Stratton website does not have a wireing diagram for my engine but if that is a kill switch wire watch should i do with it and also how do i remove the fly whell i cant tell from the diagrams i have
Kent of SW MO
06-16-2005 10:47:39
 Re: 5hp Briggs that wont start in reply to beggsie12, 06-15-2005 16:13:00
The flywheel nut is the one way clutch that the recoil pulley connects to. Remove the starter clutch/flywheel nut as an assembly.
Kent
MAC,IL
06-15-2005 11:36:00
You might try the briggs web site. You may be able to fish that model number out there and view it in PDF. Takes a little patience.
