CASE 448 Garden Tractor
Wayne Waldner
06-07-1999 08:44:23
I am looking at buying a 448 18 HP tractor with 48 inch deck and 42 inch tiller. The tractor is about 10 years old and runs good. They are asking $3500. Is this a good price? What problems should I expect with a Case 448? Any info would be appreciated.
Tim S
06-11-1999 05:10:52
 Re: CASE 448 Garden Tractor in reply to Wayne Waldner, 06-07-1999 08:44:23
I have the 448 which is 18hp instead of 16hp. The best thing about the tractor is the onan engine, I think anyway. It's not like the Briggs where it boggs down easily and I run a 60" mower with it. It makes good hp without having to be reeved all the way up. As far as the tractor, it's a pretty good tractor. I've had to replace the sector gear on the stearing, but that was only $50. I also put a lower high gear in because I have alot of hills in my lawn, the high gear was just to fast and the low range was too slow. I also found was you can run a b size belt on the mower deck rather than the a size and it wont wear as quickly and it wont slip in heavy grass. Tim
Dale
06-15-1999 20:05:49
 Re: Re: CASE 448 Garden Tractor in reply to Tim S, 06-11-1999 05:10:52
I have had my Case 448 only a short time, but I like it. I have the 60" deck. It sold for $1400 at auction with no attachments. It was in average condition with minor carburetor and electrical problems. Running fine now.
Bobcat
06-10-1999 15:59:19
Look at the serial number tag located just below the steering wheel. There is a date stamped just behind 448. That is either the model year or year of manufacture.
If it has the original engine then I think $3500 is steep. Keep in mind that a new 18 HP Onan will retail for around $1400 and new decks are pretty expensive. Is the deck in good shape?
Any other implements?
I love my 446 and would encourage anyone to invest in a used CASE.
Chuck
06-20-1999 06:09:11
 Re: Re: CASE 448 Garden Tractor in reply to Bobcat, 06-10-1999 15:59:19
Bobcat,
Regarding your comments about Case, amen brother!
Bobcat
06-10-1999 15:59:10
