54 inch mower decks
steve(ill)
07-04-2005 18:23:10
i bought a 22 HP Briggs tractor at LOWES with a 54 inch mower deck. same tractor sold at Sears and Yard Man and Husquvarna. I had a 44 inch deck sears before this. notice the new 54 inch deck seems to have a little vibration . this is an electric clutch engagement. checked the belts, pulley, idler, and clutch. NOt bad, just different than before. Is this normal?
Chad
07-05-2005 06:06:32
 Re: 54 inch mower decks in reply to steve(ill), 07-04-2005 18:23:10
If the blades ever briefly stop or slow down it will put a flat spot on the belt and cause vibration.
Kent of SW MO
07-05-2005 05:05:02
Take the blades off and check to see if they balance at the center bolt hole, if it has a center hole. When you put them back on, rotate the blades and spindle checking for a bent shaft. I know the mower is near new but you could have a bent shaft.
Kent
