Another possible soulution..
Gregg in ohio
07-06-2005 08:04:36
the spring that puts tension on the belt from the clutch was very weak..i have had this assy apart and might have put the sping in the wrong place..it really needed more tension..i repositioned the spring to another place more tension and it worked perfectly..now i just need to find the correct placement of the tension spring that goes to the frame somehwere..i have done the manual adjustments to the variator by the book..its all in the tension of the spring on the flat pulley on the main drive belt..gregg
